Fluent simulation of cavitating control valve
Old   August 31, 2019, 02:01
Default Fluent simulation of cavitating control valve
S Hossain
S Hossain is on a distinguished road
Hi All
I am new to this forum. Currently, I am working on an academic project for which I need to simulate a control valve in cavitation to understand the damage pattern. Could anybody give me some pointers as to how to start the process? I have the valve assembly (body component without actuator) and I need to simulate different opening positions (as the valve is throttling) so thinking I would need to do dynamic meshing in this case.
It would be really helpful to get some guidance so I can start the work without wasting too much time. Thanks in advance.
S Hossain is offline   Reply With Quote
Old   September 2, 2019, 01:07
MIDHUN
MIDHUN@CFD is on a distinguished road
Send a message via Skype™ to MIDHUN@CFD
if the boundaries are not moving you dont need dynamic mesh , you can write a udf which will enable closing and opening of a certain boundary at different time-step. If you want to show how the valve opens , then u need udf
MIDHUN@CFD is offline   Reply With Quote
cavitation, control valve, fluent
Problems with Simulation of a Valve with Cavitation WilbertS CFX 4 April 4, 2018 10:22
Oscillations of force and flow rate within FSI simulation of biomedical valve jtwilson FLUENT 0 September 23, 2015 14:26
1way FSI simulation using ansys structural and Fluent mmkkeshavarzi FLUENT 0 August 5, 2015 11:49
Thermal Simulation using Multiphase VOF model in Fluent hari.poudyal47@gmail.com Fluent Multiphase 0 July 20, 2015 12:31
Dynamic meshing of self-acting seat valve, how to control mesh event times? DanielBeck FLUENT 1 February 17, 2015 13:36
