Fluent - Aerodynamic coefficients are not smooth!
Old   August 26, 2019, 18:05
Post Fluent - Aerodynamic coefficients are not smooth!
Emanuel Camacho
Emanuel Camacho is on a distinguished road
Good day.
I'm currently studying the flow field around oscillating airfoils. I want to obtain the aerodynamic coefficients (drag, lift and moment) of the airfoils but these coefficients come with so much (numerical?) noise (see picture '1.png') and I still didn't find the root cause. The desired results should be something like picture '2.png'.
Notes:
- Data presented in '2.png' was filtered.
- Mesh quality is adequate.
- Y_plus parameter is correctly adjusted.
- Remeshing is activated.
- Time step seems to not have a clear influence.
EDIT 1:
- The root cause seems to be related to parallel computation.
Emanuel Camacho is offline   Reply With Quote
coefficients, dynamic mesh, fluent
How does Fluent calculate lift&drag coefficients? Fluidiculous FLUENT 5 July 2, 2016 02:36
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting arunraj FLUENT 0 June 2, 2016 23:58
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
2D NACA0015 aerodynamic coefficients computimg sailor FLUENT 1 May 3, 2011 13:58
Launch vehicle aerodynamic coefficients B. Sulejmanovic Main CFD Forum 1 April 26, 2005 10:59
