Using the TUI to write/read profiles to update BC's?
Old   August 21, 2019, 11:18
Default Using the TUI to write/read profiles to update BC's?
Sebi
bloodflow is on a distinguished road
For a cylinder of fluid with 2 phase flow, your inlet requires a VOF BC so lets put say 0.5 as an initial guess, which is applied uniformly to the inlet. In reality, this distribution may be different depending on their densities and visocisties. If you export the VOF at the outlet as a profile, and read it as the inlet VOF BC you now have a slightly better condition. If you repeat this several times you could generate a better approximation of the inlet VOF (Providing you have a cyclic velocity BC).
So far I am exporting the outlet VOF at the end of my solution using TUI, but then loading it as the inlet BC manually, and solving again using TUI and so on. Can I do this using the TUI entirely?
Some example;
PHP Code:
rc VOFProfile.cas
/solve/initialize/hyb-initialization
/solve/set/time-step 0.001
/solve/dti 800 75
/file/write-profileVOF-BC-1 outlet () highdensity-vof ()
exit
yes
Is my current TUI which export the VOF profile at the outlet. Within the same run can read this profile and apply it to my inlet? (I imagine the code would look something like this)
PHP Code:
rc VOFProfile.cas
/solve/dti 800 75
file/read-profileVOF-BC-1
/define/boundary-conditions/velocity-inlet/multiphaseVOF-BC-()
solve/dti 800 75
/file/write-profileVOF-BC-2 outlet () highdensity-vof ()
file/read-profileVOF-BC-2
Is this possible?
bloodflow is offline   Reply With Quote
Old   August 22, 2019, 00:54
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you code is here, why is it impossible?
run it
In fluent GUI you can use calculation activities -> execute commands:
read journal file each 800 time steps
so you dont need to hardcopy each write/read iteration
Check, may be periodic boundary condition is suitable for you
best regards
AlexanderZ is offline   Reply With Quote
Old   August 22, 2019, 08:51
Sebi
rc profile.cas
/solve/set/time-step 0.008
/solve/dti 100 30
/file/write-profile/ VOF-1 outlet () rbc-vof ()
/file/read-profile/ VOF-1
/define/boundary-conditions/velocity-inlet inlet rbc no no yes yes yes yes udf "CoronaryVelocityWaveform::libudf" yes no outlet rbc-vof
/solve/dti 100 30
Is the code I ended up using or with a better explanantion:
/define/boundary-conditions/velocity-inlet "name of inlet" "name of 2ndary phase" no no "yes normal to boundary" "Yes to setting up velocity udf at inlet" "name of UDF compiled" "yes to profile for multiphase" "no to UDF for multiphase" "origin of profile" "variable name"
TUI commands for sample profiles in DPM bloodflow FLUENT 4 February 5, 2020 22:23
How to set BCs programmatically incompressible OpenFOAM Programming & Development 6 November 20, 2017 03:47
Change "Implicit Mesh Update Interval" using UDF ASimonsen Fluent UDF and Scheme Programming 2 October 12, 2017 10:38
Dealing with BC's in OF 1.6 vkrastev OpenFOAM Running, Solving & CFD 5 September 4, 2012 12:58
Understanding Code behind BCs Linse OpenFOAM Programming & Development 8 January 9, 2012 09:58
