August 18, 2019, 10:36 |
Cyclone separator simulation
Seunghyun
Rep Power: 8 |
Hi, guys
This is a student who is simulating cyclone separator thesis results validation. I have tried to validate results with the following set to validate thesis CFD results, cut off size. But, I have not validated thesis results... I can send you my case and mesh files. Please contact me... * Setting up Model 1. RSM steady 6000 -> transient 20000(time step=0.001s, Max iteration/time step=40) 2. RNG ke Grids 780000 ~ 800000 Hybrid initialization Cut off size(different two designs respectively) Thesis= 0.72, 0.72 micro meter My simuation= 0.83, 0.9 micro meter |
August 19, 2019, 06:44 |
Rep Power: 11 |
Hello wayne,
I remember fighting against a cyclone some time ago, have you tried to adjust the reflection coefficients of the wall? |
August 19, 2019, 23:36 |
Seunghyun
Rep Power: 8 |
Hi sir,
Thank you for your reply. I just adjusted trap, and reflect without reflecting wall coefficients... Could you give me advice? I set up the entire dust bin as trap |
August 26, 2019, 05:14 |
Rep Power: 11 |
Hi!
By applying a reflect factor to the walls the energy of the particles will decrease, increasing the number of particles trapped by the cyclone. As a result, I would expect a lower cut off size. Anyway, this is a way of adjusting the results, in order to get a validated and solid simulation you should consider referring to literature about those factors or similar experimental setups. |
Ideas about Gas - Solid Cyclone Separator Simulations | ardismo | Main CFD Forum | 0 | January 11, 2016 11:46 |
Cyclone reference paper request!! | Eakarach | FLUENT | 0 | December 17, 2015 12:59 |
Particle separation in an axial cyclone | Cloudseeker | CFX | 3 | August 19, 2014 21:13 |
Steam-Water Vertical Cyclone Separator | Munggang | FLUENT | 3 | April 29, 2014 14:38 |
Modelling Industrial cyclone behaviour | Günther Hasse | Main CFD Forum | 3 | October 12, 1999 20:34 |
