Laminar flow over an airfoil in Fluent does not converge
Old   August 14, 2019, 08:01
Exclamation Laminar flow over an airfoil in Fluent does not converge
oci95 is on a distinguished road
I'm running a study of a simple curved plate, I've created a structured mesh with ICEM, imported in fluent.
I think the mesh is enough fine (see the attachment) and shouldn't be the problem. (The plate is not visible because it's a simple curved line and it coincides with an edge of the mesh, anyhow the foil is exactly one of the curved lines)
Initially I've run some 2D, steady, laminar, pressure based simulation but the continuity residual converge at about 1.5e-3 and I think it's not enough.
I've looked for on the forum and I found out that I should run a transient simulation. I've done it with time step of 0.001s but the result is the same: the continuty (white line on the attachment) converge at about 1.5e-3 and it doesn't go down.
I don't know what else could I do.
Re is 20700, but also with Re=2133 the result is the same.
Bounday conditions are:
  • Velocity inlet
  • Pressure outlet
  • Periodic (on top and bottom of the domain)
  • Wall (for the foil)
I've try also to use a turbulent model but the result is the same.
oci95 is offline   Reply With Quote
Old   August 14, 2019, 11:05
sufjanst is on a distinguished road
Maybe you should use turbulence models.
If you have a turbulent flow due to high velocities, the laminar "model" will hardly be able to give you a stable solution.
If I remember correctly, people use the laminar "model" with a extremely fine mesh to do DNS because the turbulence is directly calculated and not modelled which is clearly not what you are trying to achieve.
sufjanst is offline   Reply With Quote
Old   August 14, 2019, 11:16
I forgot to write that the Re is 20700, which should be perfectly laminar flow.
Anyway i've try to use also a turbulent model but the result is the same.
Old   August 27, 2019, 06:15
Janet J
Janet is on a distinguished road
Attachment 71788
Attachment 71789
  • Velocity inlet
  • Pressure outlet
Increase the time steps maybe? To 0.1? And try. Changing the Courant number may also help converge. For coupled-explicit solver, Stability constraints impose a maximum limit on Courant number, and it cannot be greater than 2. Default value is 1. Reduce Courant number when
having difficulty converging. But sometimes even this does not help, you can try. For implicit, it is 5, which can be reduced too.
Janet is offline   Reply With Quote
convergence fluent, convergence issues, convergence problem, fluent, transient 2d
simpleFoam vs Fluent for laminar flow. What is going wrong? CabreraLucas OpenFOAM Running, Solving & CFD 1 February 4, 2019 04:20
laminar and turbulent flow simulation in elbow fitting to find K values wtr Re prashanth1234 FLUENT 4 January 18, 2019 11:06
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Fortran code for laminar flow around naca0012 airfoil kianoosh_py Main CFD Forum 19 September 13, 2015 07:19
Question about Laminar flow over flat plate in FLUENT gaoyitong FLUENT 0 November 26, 2012 23:51
