Rotating cylinder ht
Old   August 9, 2019, 07:18
Default Rotating cylinder ht
crinoid
crinoid is on a distinguished road
I want to model the heat transfer of a rotating cylinder (1500 rpm) to static air. What domain should I use? I am using a kind of donut with 2 concentric circles (one for my cylinder, in which I set a constant temperature and a rotational speed) and another for the exterior (in which I don't know what bc to use).
I've already tried several bc but the results aren't good. What do you recomend me?
crinoid is offline   Reply With Quote
heat transfer, rotating cylinder
[ANSYS Meshing] complicated motion of a rotating cylinder? Vamsi ANSYS Meshing & Geometry 0 April 9, 2016 01:32
Forces Acting on a Rotating Cylinder (Moving Mesh) dreamchaser CFX 5 April 25, 2015 07:01
Mesh type in rotating blade inside cylinder Mah.tavana Mesh Generation & Pre-Processing 0 July 26, 2014 07:53
Flow past rotating cylinder sam.ho OpenFOAM Running, Solving & CFD 4 October 10, 2013 08:49
Rotating cylinder Johnny Main CFD Forum 5 December 7, 2004 10:55
