GHow to define UDF for Density in Ansys Fluent? and How to remove Error?
Old   July 30, 2019, 08:26
Default GHow to define UDF for Density in Ansys Fluent? and How to remove Error?
Azim Memon
Azim07 is on a distinguished road
i want to define the density in the in the form of Equation by UDF in ansys fluent of the following equation.
rho = 885/(0.0008(temp-321.35)+1)
i have written the following UDF
and it shows the following Error
https://www.cfd-online.com/Forums/at...1&d=1564485883
How can i solve this problem or any other way i can simply Define UDf in Easy way?????
Azim07 is offline   Reply With Quote
Old   July 31, 2019, 00:58
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
next time put here code, not picture
you've defined temperature as
real temp = C_T(c,t);
but later in equation you are using t (which is thread actually) but not temp
change t to temp in equation
best regards
AlexanderZ is offline   Reply With Quote
