July 28, 2019, 02:58 |
DPM convergence, URF
mahshid ansari
Hi
I have been trying to simulate a 2D laminar nanofluid flow around a triangular obstacle by applying the discrete phase model (DPM) based on data below: paper title: "discrete particle model for convective AL2O3-water nanofluid around a triangular obstacle": http://dx.doi.org/10.1016/j.applthermaleng.2016.01.076 - AL2O3-water nanofluid with the particle volume fraction of 5% - particle mass flow rate injected from the inlet surface (about 17 kg/s) every 0.008 seconds - two-way coupled model - thermophoresis and Brownian forces are included the problem is that after a few time steps, the message " temperature limited to '-' in '-' cells" appear in the console window, followed by the "floating point" error which terminates the calculations altogether. I have read somewhere that the source term URF needs to be changed constantly through the run process and if so, I have no prior experience in this area. Therefore, I'd appreciate it if anyone could share their thoughts on how to solve this problem. |
convergence, dpm model, nanofluid, under-relaxation factor |
Group DPM injection - pathline convergence | A_Keen | FLUENT | 0 | July 4, 2019 14:20 |
Rising residual behaviour and convergence | tjim | SU2 | 0 | October 12, 2018 04:04 |
DPM convergence | unnikrishnan | FLUENT | 0 | October 20, 2015 02:47 |
how to ensure convergence for DPM | Soubhik | FLUENT | 1 | February 11, 2007 16:55 |
dpm and edc convergence | luigi | FLUENT | 0 | March 22, 2006 07:34 |
