July 27, 2019, 05:01 |
Import surface as surface (not interface)
Jordi Iglesias Deutu
Hello
I have a complex geometry with many holes, to know the flow rate in each hole, I created some surfaces in Spaceclaim. When I open Fluent after meshing, these surfaces become automatically an interface, how can I import them as a surface just to monitor flow rate? Create the surfaces inside fluent is much more complicated. Thank you so much in advance! |
flow rate, fluent, import, interface, surface |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 02:44 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 05:31 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
