Jacques
Rep Power: 7 ![]() |
Hey there ! I tried asking in the freelancer cfd threads but noone seemed able to help. I am trying my luck here
![]() I am trying to set up porous media condition to compute the effects of a thin sheet with holes at (fe) 45 degrees. I have the data of the pressure loss for a given flux which i fitted to get the permeability and inertia lots coefficients. I then tried various method but none gave satisfying results. I tried source terms with a calculated new porosity matrix given by a rotation of 45 degrees. It worked but i had to use the porous jump in fluent and remove said jump in the udf along with the rotation to make it work. I also tried to use the direction vector, setting dir 1 to the 45 degrees direction of the holes and dir 2 to the orthognal vector in the sheet plane. It worked too. However both methods leave me puzzled as i need to set the orthogonal coefficients to arbitrary but needed values in order to control the pressure loss. I would have assumed that setting those to high enough value would leave me with a flow at 45 degrees whose pressure loss is controlled by the porous coeficients in the direction 1. Apparently not. What am i missing ? Is there a way to achieve what i want ? Namely making a flow in a given direction and controlling the pressure loss with this direction instead of setting it to 0 and manually changing the other two (irrelevant) directions coeficients to match the required pressure loss. I didn't try porous jump and a udf to fix the velocities at 45 degrees and then adjusting the porous jump to match the required pressure loss. I hope it's not too complicated a request and my explanations are clear enough. I'll try to clarify if so ! Thanks for your help ![]() |
arman
Rep Power: 10 ![]() |
hello everybod
i have a few problems for solving Porous media in fluent. im dont know that how can import the numbers for various resistanc and inerial resistance.i dont undrestand where these numbers from are? also i have second problem about source term icon and menu about porous menu. pleas help me about those problem. thancks |
arman
hi everybody
i have same problems |
Multiphase Porous Media Flow - Convergence Issues | VT_Bromley | FLUENT | 8 | May 30, 2024 02:59 |
Porous sheet with thin holes at a given angle | zog | CFD Freelancers | 2 | July 29, 2019 01:20 |
direction vector in porous media | arash.mp | FLUENT | 0 | April 1, 2019 10:06 |
fluent 2D axisymmetric with swirl simulation with porous media | user0314 | FLUENT | 1 | June 11, 2015 02:57 |
Porous media Definition in FLUENT | Rashmi | FLUENT | 0 | May 13, 2006 00:55 |
