July 20, 2019, 10:13 |
Open Fluent on Windows like the way on Linux
zizhou huang
Rep Power: 7 |
As mentioned in the following website, Fluent together with the journal file can be opened directly in the terminal on Linux.
https://www.sharcnet.ca/Software/Flu...execution-unix There is also a page teaching how to open Fluent on Windows, however, the journal file can only be loaded after entering Fluent. https://www.sharcnet.ca/Software/Flu.../ug/node13.htm When I tried to load journal file like the way on Linux, it says "Error: eval: unbound variable". Is there any way to avoid this error? Thank you! |
July 21, 2019, 14:08 |
Lucky
Rep Power: 66 |
July 22, 2019, 09:06 |
zizhou huang
Rep Power: 7 |
Thank you very much!!
terminal, windows |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 03:50 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
Fluent - Linux vs Windows | derick | FLUENT | 2 | August 16, 2020 11:23 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
