how to define two boundary conditions on a surface
Old   July 17, 2019, 12:33
Red face how to define two boundary conditions on a surface
Tamil Nadu
abhinavrajan is on a distinguished road
how to define heat flux at a surface and heat losses form same surface at the same time in Fluent?
abhinavrajan is offline   Reply With Quote
Old   July 17, 2019, 15:51
Lucky
What do you mean by heat loss? And why is that not the same as a heat flux? How can you have 2 boundary conditions? You have a boundary condition, and that's it. Please explain...
Old   July 17, 2019, 16:14
Tamil Nadu
If I am giving heat input to a curved surface of receiver of solar dish collector, there will be convection and radiation heat transfer from the same surface at same time to ambient.
In this condition, I can not define the mix thermal conditions at surface at which heat flux thermal condition already applied.
how to figure out the heat going to ambient due to convection and radiation from surface which has a heat flux input?
Old   July 19, 2019, 10:15
Lucky
You can probably use the mixed thermal condition in fluent and model your solar load as a volumetric heat source.
Give it the htc and free stream temperature for convection. If applicable, give it the emissitivity and radiation temperature for the radiation losses.
Then use the heat generation rate and give your wall a thickness such that you get the desired solar load.
ansys 18.1, boundary condition, fluent, heat flux., heat losses
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 18:19
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 11:19
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
