How about a multicomponent combusting particle |
sid mez
Rep Power: 10 ![]() |
When using DPM model in fluent, then injection, it is available a combusting particle where you can use char+1component (species) of a liquid that can evaporate. Otherwise a multicomponent particle where you can use multi component (multi species) liquid but doesnt include char, volatiles or solids . The problem is what to do if i want to model a particle with a char(volatiles, solid) and a multi component liquid species ? Thank you. |
combusting particle, combustion modeling, dpm model, multi component |
UDF for multicomponent particle vaporization | Mohsin | Fluent UDF and Scheme Programming | 17 | January 27, 2021 02:57 |
UDF for particle interception with pt_termination fortran routine | abcdefgh | CFX | 6 | October 6, 2019 13:30 |
Particle tracking error | alchem | OpenFOAM Bugs | 5 | May 6, 2017 16:30 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
