Transition over airfoil using k-kl-omega model |
July 16, 2019, 10:20 |
Antoine
Hi !
For my project I'm supposed to study the flow transition from laminar to turbulent around an aerofoil of a racing car. I've done several analysis using the k-kl-omega model on FLUENT and the thing is, I don't know which variable is the most accurate to say where the transition occurs on the aerofoil... Should I use the Cp plot, the turbulent viscosity plot, the specific dissipation rate (omega) plot or the turbulent kinetic energy plot ? And also, is the eddy viscosity contour good to get an idea of where the transition occurs ? Thank you for your help. Antoine PS: I have attached some of the plot and contour I did for a k-kl-omega analysis using a 8deg angle of an Eppler-387 aerofoil. |
July 16, 2019, 11:12 |
Lucky
Rep Power: 66 |
Isn't there an intermittency factor which tells you whether the flow is laminar or turbulent, with values between 0 and 1 representing the transition region?
transition isn't a binary trait, it is a phenomenon. Each of these variables can be used to define a transition (each in a different kind of sense). |
July 17, 2019, 05:21 |
Antoine
Thank you for your answer !
Well, I have actually heard about this intermittency factor on Fluent but I haven't been able to make it work... Do you know how to set it up ? |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 08:18 |
CFX transition model issue with VATT | PLD | CFX | 5 | April 22, 2014 06:21 |
k omega turbulence model | sailspace | OpenFOAM Running, Solving & CFD | 0 | November 12, 2013 06:43 |
Transition Model - Gamma Re Theta | nomad | STAR-CCM+ | 5 | April 17, 2011 09:34 |
Use of k omega turbulence model | john_w | OpenFOAM Running, Solving & CFD | 2 | September 22, 2009 06:15 |
