Help to detect the cause of divergence
Old   July 15, 2019, 09:33
Default Help to detect the cause of divergence
Josh
Helium is on a distinguished road
Hi guys,
I am performing a simulation where air flows through a heated channel (DO model and energy eq. on). Essentially my aim is to see how temperature of fluid varies when air leaves out from the outlet (pressure outlet). The simulation is perfectly normal till 500 iterations: at this point, there is a peak in continuity equation and air velocity raises to the incredible value of 250000 m/s (velocity inlet at 1 m/s as starting value). Okay, the channel is not so large (it's just few mm), but honestly this does not justify this situation...
Mesh quality is also okay and model dimensions are good... I do not know what to think, this never happened to me before.
Ideas?
Thanks
Helium is offline   Reply With Quote
Old   July 15, 2019, 15:46
seph is on a distinguished road
Might be the DO model, have you tried without radiation? Maybe also try the P1 or other models.
seph is offline   Reply With Quote
continuity equation, divergence, error, problems
PEMFC model with FLUENT brahimchoice FLUENT 22 April 19, 2020 16:44
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
Two Phase Flow In Vertical Pipe stonepreston FLUENT 2 October 31, 2017 09:35
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
Divergence problem Smaras FLUENT 13 February 21, 2013 06:03
