Rep Power: 8 ![]() |
Hello everyone,
I have a simple flow field, on which I activated the Discrete Phase Model to introduce some Mass Less Particles - from an inlet to an outlet. This is working quite well. With the Fluent integrated Particle Tracker I'm able to look at the trajectories of the particles. What I need now is to export this data. I am aware of the Export -> Particle History Data option. However I'd like to couple this information with more solution data. That means, for example, I have 1 particle trajectory where I want to save temperature, pressure and velocity as additional "columns". Is this by any means possible from the Fluent interface? Or do I need to merge the particle history data and solution data bymyself? Thanks in advance! |
Particle Residence Time export using DPM Model | TimNum | ANSYS | 0 | July 4, 2019 06:34 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
Exporting Particle Data | prX411 | CFX | 4 | April 3, 2018 12:00 |
A CFX-POST error (ver 14.5.7) | wangyflp88 | CFX | 2 | July 22, 2017 00:17 |
export data at nodes | Meenu | FLUENT | 1 | December 30, 2011 01:24 |
