Aerodynamic roughness length to equivalent sand-grain roughness?
Old   July 12, 2019, 02:51
Default Aerodynamic roughness length to equivalent sand-grain roughness?
Shannon Kieran
Shanny is on a distinguished road
I am carrying out a Fluent simulation for a city block. In order to set the appropriate surface roughness for the wall boundary condition for the ground surface, I need to specify the sand-grain roughness height (Ks). However, because it is an atmospheric boundary layer problem, not a pipe system, the surface roughness parameters I do have are the aerodynamic roughness length (zo), and also approximate drag cofficient (Cd).
I've had a look at the theory guide, user guide and also various textbooks but haven't had any luck finding out how I can convert zo or Cd to an equivalent approximate Ks.
Any assistance would be appreciated!
(I am a university student)
Shanny is offline   Reply With Quote
Old   July 12, 2019, 05:17
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may try to find something here
https://www.sciencedirect.com/search...rtBy=relevance
best regards
AlexanderZ is offline   Reply With Quote
Old   August 19, 2019, 22:01
Default Solved
Shannon Kieran
Just thought I would post the following in case anyone has the same question later on.
I eventually found the answer to my question in this article:
Blocken B, Stathopoulos T, Carmeliet J. 2007. CFD simulation of the atmospheric boundary layer:– wall function problems. Atmospheric Environment 41(2): 238-252. © Elsevier 2007.
Old   November 15, 2019, 11:16
anarchitect
mimarilker is on a distinguished road
I have read this article for numerous times, but it does not offer an exact solution. Could you please share how you solved your problem?
mimarilker is offline   Reply With Quote
Old   August 7, 2020, 12:50
mz_uon is on a distinguished road
This paper offers a direct solution to equivalent sand grain height, as is needed to be input in Fluent for ABL simulation
http://www.cobee2018.net/assets/pdf/p/063.pdf
mz_uon is offline   Reply With Quote
Old   May 29, 2024, 17:21
Moataz
MoaMD is on a distinguished road
the link is broken, could you please provide the title of the paper? thanks in advance
MoaMD is offline   Reply With Quote
roughness height, wall boundary conditions
Equivalent sand grain roughness alternatives arun1994 Main CFD Forum 5 May 9, 2018 12:38
Equivalent length of helical coil Jeffreyb723 Main CFD Forum 0 August 18, 2017 23:26
equivalent sand roughness height LSC CFX 3 December 23, 2012 13:50
Roughness length, interpolation, unphysical dissipation rate on the ground apaleftos STAR-CD 0 February 14, 2011 05:37
equivalent sand grain roughness attax CFX 0 September 8, 2005 10:44
