Moving tank in the water?
Old   July 3, 2019, 11:20
Default Moving tank in the water?
Josh
Helium is on a distinguished road
I need help to simulate a situation where a tank (partially filled with some liquid) is surrounded by water. Basically, I need to evaluate the effect of external movement of water on the internal liquid. I was thinking to use a sloshing-type setup to create waves in the external water (by UDF), but honestly I do not know if these waves will then influence also the movement of the fluid in the tank. But, also important, I ignore how to set a random movement for the tank (it is moved by waves because basically it's not anchored to anything)... maybe I should create a UDF for moving-walls boundary condition?
Is it possible to create a situation like this? Any ideas?
Thanks
Helium is offline   Reply With Quote
dynamic mesh, moving walls, sloshing tank, udf, waves
Heating up a water tank Seeth STAR-CCM+ 8 October 23, 2018 07:11
Simulating water movement up and down in a tank walte ANSYS 1 October 19, 2018 14:38
Water flow in large tank 2d, axi, VOF jarekk91 FLUENT 0 February 16, 2018 05:47
BC for object moving in water maply007 COMSOL 6 March 20, 2010 05:41
Evaporating water from a tank Juan Catelén CFX 0 January 10, 2008 13:08
