how to convert ppm to volume fraction in ansys fluent? |
July 3, 2019, 05:48 |
far
Rep Power: 7 |
hello, how can i convert nanofluid( 500ppm) with specified density of nano particle(300kg/m3) and 5 litres of this nanofluid to volume fraction .beacuse in ansys for second phase i need volume fraction. can i change ppm to volume fraction in ansys? if not, how can i convert it?
July 6, 2019, 07:42 |
Svetlana Tkachenko
Rep Power: 15 |
Depends on the particle size.
Particle volume fraction = All particles volume / Volume of the fluid = One particle volume * number of particles in this volume / Volume of the fluid = One particle volume * (ppm * Total volume of container / Volume that passes per minute) / Volume of the fluid = One particle volume * ppm * Total volume of container / (Volume that passes per minute * Volume of the fluid ) = One particle volume * ppm / (Volume that passes per minute) = (4/3 pi R^3 m^3) * 500 min^-1 / XXX m^3/min = ... (dimensionless) You will need the particle size R and your volumetric mass flow rate XXX (converted to a value per minute, or convert the 500 min^-1 to a per-second value by dividing it by 60). |
concentration, multiphase mixture, ppm, second phase, volume fraction. |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 15:05 |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 17:12 |
multiphase turbulance case floating error | harsha_kulkarni | OpenFOAM Running, Solving & CFD | 3 | February 18, 2016 06:06 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
interDyMFoam - change in volume fraction | gopala | OpenFOAM Running, Solving & CFD | 0 | April 27, 2009 11:46 |
