Porous media in FLUENT
Old   June 28, 2019, 13:12
Default Porous media in FLUENT
Chaatouf Dounia
Dounia is on a distinguished road
Hello everyone!
I was simulating a square box with trays as a porous media, where the air is flowing from the inlet passing by the porous media and then go out from the outlet. I only entered the power-law coefficients C0 C1 and the porosity. but then I realised that there is something wrong with it, because I found that in both cases with or without porous media it shows the same results.
Is it wrong to use just the power law model without the inertia and permeability coefficients ?
so I was wondering if someone can help me with this and show me how to simulate a porous media using the power law coefficients.
I'll be so grateful for any comments or answers.
Best regards,
Dounia
Dounia is offline   Reply With Quote
Old   July 2, 2019, 16:56
Vaelyn is on a distinguished road
Use those coefficients on those boxes right above, on viscous and inertial resistances. Use the same value on all the coordinates, as assuption of isotropic material (which the power law itself implies).
Vaelyn is offline   Reply With Quote
Old   July 3, 2019, 05:12
Chaatouf Dounia
I tried it before, unfortunately, it didn't work. the same result shows each time.
by the way, thank you for answering me I really appreciate it.
Best regards,
Dounia
Thermal non-equilibrium porous media model with conjugate heat transfer Hexahedron FLUENT 9 February 22, 2023 03:55
porous media in FLUENT Natalie2210 FLUENT 7 August 15, 2019 13:46
stuck in FLUENT porous media option annu FLUENT 0 November 7, 2017 05:46
porous media model validation Tensian FLUENT 0 September 23, 2016 06:04
analysis of multiphase and porous media in ansys fluent ahmed_khatibs FLUENT 0 November 4, 2014 13:01
