June 25, 2019, 20:48 |
Bioventing 3D model- Fluent
Mohammad khodabakhshi
Rep Power: 7 |
Hello, I am working on a project (see below) and I need to make sure that Fluent module is capable of modelling my system, please help me go through it.
The system we are going to simulate has been described below: A cylindrical reactor filled by contaminated soil including one/some venting well(s) is going to be simulated; the venting well induces gas flow through the cylindrical reactor, which contains hydrocarbons-contaminated soil. The radial air flow comes from the outer radius and flows toward the extraction well(s) in the center of the reactor. In order to identify the governing mass transfer processes, a three-dimensional numerical model is going to be developed. We are going to use a software that incorporates multi-phase flow, multi-component transport and non-equilibrium transient mass transfer. The mass transfer mainly occurs between the following phases: aqueous and non-aqueous phase liquid (NAPL) phases to vapor phase; NAPL phase to aqueous phase and aqueous phase to solid phase. In the meanwhile, a biodegradation reaction occurs in the reactor which is considered a first order reaction, so biodegradation rate correlation should be also applied to the model. If you need any other details on model please let me know |
Seeking Macroscopic Particle Model in Fluent | bzhang7 | FLUENT | 3 | June 25, 2022 18:54 |
Ansys Fluent (K-Epsilon) Model | gshankarau | FLUENT | 0 | September 27, 2016 07:30 |
Ansys Fluent K-Epsilon Model | gshankarau | FLUENT | 0 | September 23, 2016 06:59 |
Fluent :- turbulence Model | prince_pahariaa | FLUENT | 9 | May 20, 2016 04:41 |
How to create a 3Ds Car Model importing to FLUENT? | spysunny | Main CFD Forum | 1 | January 11, 2012 00:40 |
