Fluent-Skin friction coefficient contours problem
Old   June 25, 2019, 15:48
Default Fluent-Skin friction coefficient contours problem
ozturk sancaktar
ozturk is on a distinguished road
Using Ansys Fluent, I wanted to calculate the CL and CD coefficients for a 3D airfoil with a speed of 22 m/s. We created inflation layers and the first element height is calculated for y plus equals to 1. I used kw-SST as the turbulence model. I also compared the results with the Lifting Line Coupled xfoil results. In my analysis with 1.8 million mesh, the CL and CD results were almost identical. I have saved the results of the fluent solution with the Tecplot method and compared the contours with Lifting Line Coupled xfoil results. There was slight oscillation in pressure coefficient contours while skin friction contours were discontinuous. I increased the number of mesh (nearly 6 million) and the minimum orthogonal quality was 0.03 and max. skewness was 0.9 and we used the model as transition SST. Even though the results were consistent, the skin friction coefficient contours were still discontinuous.
How can we improve skin friction coefficients contours?
ozturk is offline   Reply With Quote
Old   June 29, 2019, 17:14
ozturk sancaktar
I need your help. Help
Thank you.
Fluent - license problem. Marcin FLUENT 3 April 13, 2018 17:33
time average of pressure and skin friction coefficient in the entire domain SUBHANKAR OpenFOAM Post-Processing 2 April 11, 2017 09:46
All zeros: Skin Friction Coefficient, Heat Flux, Y Plus LetsCFD SU2 1 June 18, 2016 12:12
Skin friction coefficient Anna Tian CFX 3 January 28, 2013 10:25
Macro for skin friction and pressure coefficient DoHander Fluent UDF and Scheme Programming 0 January 9, 2010 11:18
