boussinesq approximation when temperature difference is large
Old   June 25, 2019, 00:11
Default boussinesq approximation when temperature difference is large
HakminLee
a.lone is on a distinguished road
I'm studying on the natural convection of spent fuel in the dry storage system.
I understand that boussinesq approximation can be used only when the temperature difference is small.
If the temperature range is 300K-500K for example, is it right to simply use an incompressible ideagl gas law that uses the p=rho*R*T law?
Or can i just use the boussinesq approximation?
i don't know about these.
Thank your reply.
a.lone is offline   Reply With Quote
Old   June 25, 2019, 12:38
Erik
evcelica is on a distinguished road
That temperature range is too large for Boussinesq. I've heard 10% density difference maximum. Ideal gas is not incompressible, it is definitely compressible, and using that for density would be much more appropriate.
evcelica is offline   Reply With Quote
Old   June 25, 2019, 21:20
HakminLee
Thankyou so much!
Old   September 15, 2020, 16:07
Sai Krishna
Sai Krishna is on a distinguished road
Hi evcelica,
I have a doubt regarding coefficient of thermal expansion which we use in boussinesq approximation.
I am doing simulation for natural convection for a pcb in an enclosure. the freestream temp is 322K. i read bousinesq approximation is valid iff
beta * (T-T_ref) <0.05. in this for beta what should I consider. my fluid is air and as its an ideal gas beta = 1/T. so here what temperature should I use.
Thanks for the help
Sai Krishna is offline   Reply With Quote
boussinesq approximation, natural convection
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
Difference between convective heat transfer and fixed temperature jpina FLUENT 4 March 14, 2016 09:22
Natural convection without boussinesq approximation shahrooz.omd Main CFD Forum 0 June 23, 2015 09:03
Difference between HF and Temperature BCs Catthan FLUENT 0 August 7, 2013 06:59
Boussinesq approximation again Gabriel Main CFD Forum 3 May 11, 2000 10:24
