FLUENT 19.2 User Defined Real Gas Model udf problem |
June 22, 2019, 16:40 |
mohammad karimi pour
Rep Power: 8 |
Hello
I've copied the exact same udf of UDRGM of ANSYS HELP 19.2 Ch.7, which is simply EOS for ideal-gas, to a ".c" file, then compiled it. First, I got: ** WARNING: Automatically switched to run in parallel -t1 mode. ** ** Detected non-parallelized UDF usage, enabling parallel usage. ** ** If you encounter any issues, please re-run with -t0 flag. ** which vanished when I started fluent->parallel with 0 processors. Anyway, when the material is air with ideal gas setting of database everything is OK, but when I use the UDRGM this error emerges: iter continuity x-velocity y-velocity energy time/iter Stabilizing x-momentum to enhance linear solver robustness. Error: Divergence detected in AMG solver: x-momentum Error: Divergence detected in AMG solver: x-momentum Error Object: #f Is it a problem of version of Fluent or it has something to do with serial/parallel udf? https://www.sharcnet.ca/Software/Ans...gas_udrgm.html |
June 23, 2019, 21:39 |
#2 | |
Alexander
Rep Power: 34 |
Modified k-e turbulence model UDF | Travis | Fluent UDF and Scheme Programming | 7 | November 11, 2018 20:21 |
UDF for Real gas model | Kirill-MIPT | Fluent UDF and Scheme Programming | 8 | September 7, 2018 07:16 |
udf for valve closing a pipe using dynamic mesh | chem engineer | Fluent UDF and Scheme Programming | 2 | May 13, 2017 09:39 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Parallelizing a UDF | tstorm | Fluent UDF and Scheme Programming | 3 | August 20, 2009 12:31 |
