UDF and /bigobj error
Old   June 21, 2019, 16:27
Default UDF and /bigobj error
ansys_matt is on a distinguished road
I have run into an error when compiling a very large UDF. The error looks like this:
fatal error C1128: number of sections exceeded object file format limit: compile with /bigobj
If you do some searching you will see that the /bigobj compiler flag can be used to overcome this error, but I am not sure how to get ANSYS to recognize it.
One approach I thought of was to compile the udf directly in Visual Studio instead of having ANSYS compile it by calling Visual Studio under the sheets. But I am not sure what I need to do to compile directly in VS and then use the object file in ANSYS.
Does anyone know how to do this?
ansys_matt is offline   Reply With Quote
Old   June 23, 2019, 22:42
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
split your UDF into several files
best regards
AlexanderZ is offline   Reply With Quote
bigobj, error, fluent, udf
