Separate cells by IsoSurface?
Old   June 18, 2019, 04:24
Default Separate cells by IsoSurface?
vidyadhar
vidyadhar is on a distinguished road
Is it possible to separate cells by an iso-surface of VOF=0.5?
This iso-surface of VOF=0.5 divides each interface cell equally. So, I want to separate the fluid domain based on this iso-surface inorder to delete the fluid region on one side of this iso-surface.
My fluid domain contains liquid with vapor above it.
Thanks & Regards,
vidyadhar
vidyadhar is offline   Reply With Quote
Old   June 18, 2019, 09:15
Default Deleting Vapor Cells from Fluent VOF simulation?
vidyadhar
I have done VOF simulation using ANSYS Fluent. I have obtained an interface with liquid and vapor on either side of the it. I want to delete the vapor cells from the domain and make the interface as a WALL. I am marking cells with volume fraction from 0.5 to 1 and deleting them.
When I try to do this, a zig-zag shaped WALL is forming instead of a smooth interface WALL.
How to avoid zig-zag shaped WALL and to obtain a smooth interface WALL after deleting vapor cells?
In literature: People have extracted images of the interface and bounding solid walls and meshed the volume containing liquid only. Even if someone suggest how to achieve this it would be great.
Thanks in advance!
vidyadhar
vof phase change
[snappyHexMesh] snappyHexMesh does not remove internal cells Binglian Hu OpenFOAM Meshing & Mesh Conversion 16 June 3, 2021 10:38
[snappyHexMesh] SHM Layer Addition Phase dickcruz OpenFOAM Meshing & Mesh Conversion 4 November 1, 2018 08:05
[snappyHexMesh] snappyHexMesh matches wrong cells to CellZone Siegunn OpenFOAM Meshing & Mesh Conversion 4 July 31, 2015 06:10
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
