Significant changes in parameters after I resume FLUENT simulation
Old   June 16, 2019, 07:00
Default Significant changes in parameters after I resume FLUENT simulation
South Yorkshire
asking is on a distinguished road
I am running a simulation of a vibrating cylinder subjected to a constant flow rate. The model works fine and the cylinder moves as expected.
I saved the simulation every 100 time-steps and I have problems when I resume it from the last saved time-step in a different computer. Basically, the scaled residuals increased drastically and most of the parameters that I am saving also increase significantly.
From time step 14000 to 14001
Lift: from -0.02 to 0.45
Yplus: from 0.86 to 2.29
Drag: from 0.07 to 9.88
Due to this increment, eventually my model fails due to negative cell volume problem.
I resume the simulation from Fluent going to File - import - case and data, and selecting the last saved time-step. Then, I copy the UDF with its corresponding folder "libgen" and just run the simulations.
Any suggestions would be really appreciated.
Regards
asking is offline   Reply With Quote
Old   June 17, 2019, 06:41
South Yorkshire
I have narrow it down to the UDF. It seems that my problem is almost the same as the one in this thread:
problem restarting dynamic mesh cases
Specifically, the solution seems to be in this response:
Originally Posted by `e` View Post
Not quite. Consider the restoring force from earlier:
\textbf{F} = -k (\textbf{x}_\textrm{cylinder} - \textbf{x}_\textrm{equilibrium})
If you only want a single DOF such that the restoring force of the spring acts purely in the y-direction, then the force on the cylinder could be calculated with:
force = -k*(DT_CG(dt)[1] - x_equilibrium[1]);
where the DT_CG macro is the centre of gravity vector of the dynamic thread zone and x_equilibrium is the vector where the spring is at equilibrium (defined within the UDF). The UDF manual has examples and details for further clarification and reference.
Note: remember that indexing in C starts from zero instead of one, so DT_CG(dt)[1] corresponds to the second spatial coordinate (y for Cartesian).
But I am not sure how to implement it in my UDF, here is my code that solves the equation of motion
for (i=0;i<3;i++)
cg[i]=DT_CG(dt)[i];
vcg[i] = DT_VEL_CG(dt)[i];
/*Numerical methods*/
/*Numark-beta*/
real beta = 0.25;
real gamma = 0.5;
real term0 = (1/(beta*dtime*dtime))*(mass+ad_mass) + (gamma/(beta*dtime))*c;
real term1 = (1/(beta*dtime))*(mass+ad_mass) + ((gamma/beta)-1)*c;
real term2 = ((1/(2*beta))-1)*(mass+ad_mass) + dtime*((gamma/(2*beta))-1)*c;
real Keffx = k + term0;
real Reffx = fx*(water_depth/length) + term0*cg[0] + term1*vx + term2*ax;
real Keffy = k + term0;
real Reffy = fy*(water_depth/length) + term0*cg[1] + term1*vy + term2*ay;
Message("Velocity: %f \n",vy);
dx = Reffx/Keffx - cg[0];
dy = Reffy/Keffy - cg[1];
x += dx;
y += dy;
real vprev_x = vx;
vx = (gamma/(beta*dtime))*dx + (1-(gamma/beta))*vx + dtime*(1-(gamma/(2*beta)))*ax;
ax = (1/(beta*dtime*dtime))*dx - (1/(beta*dtime))*vprev_x - ((1/(2*beta))-1)*ax;
real vprev_y = vy;
vy = (gamma/(beta*dtime))*dy + (1-(gamma/beta))*vy + dtime*(1-(gamma/(2*beta)))*ay;
ay = (1/(beta*dtime*dtime))*dy - (1/(beta*dtime))*vprev_y - ((1/(2*beta))-1)*ay;
It seems that when I resume my calculations, some values go back to zero and not the last values they had in the last saved time step.
fluent
How to resume a stopped simulation Pallav OpenFOAM Running, Solving & CFD 29 November 18, 2024 02:41
Results of an axisymmetric simulation in Fluent ShimiSan FLUENT 0 July 19, 2016 10:20
Acoustic Simulation in Fluent (Pre-defined sound source) bassam693 FLUENT 1 January 2, 2016 08:06
Resume Transient simulation HMR CFX 1 June 28, 2011 22:13
resume and run fluent for another timestep via a c greg FLUENT 2 June 30, 2005 06:01
