how to define diffusion coefficients for every species in the system?
Old   June 15, 2019, 11:45
Default how to define diffusion coefficients for every species in the system?
Weiqiang Liu
Weiqiang Liu is on a distinguished road
Hi all,
I wrote an UDF to define mass diffusion coefficients for all species in the system. For some reason, I need to hook my UDF in mixture material panel instead of single specie panel.
My UDF can be compiled and loaded without error. I also checked the returned value of mass diffusion coefficient which is 4.6e^-5. However it is only for one specie. In specific, specie index "i" is always 0 in DEFINE_DIFFUSIVITY(c,t,i) macro.
I wonder how can I define mass diffusion coefficients for every species in the system if I have to hook my UDF in mixture material panel?
Best.
Weiqiang.
Weiqiang Liu is offline   Reply With Quote
Old   June 16, 2019, 17:05
Weiqiang Liu
it turns out fluent can loop all the species in the system even if I hook my UDF in mixture panel.
Though it returns wrong value which I can not understand.
best
Weiqiang
Old   September 26, 2019, 23:37
david
qkhanh189 is on a distinguished road
best
Weiqiang
Have you solved this problem yet?
qkhanh189 is offline   Reply With Quote
Old   September 28, 2019, 10:41
Weiqiang Liu
I think yes. You just need to hook your UDF in mixture panel and fluent will loop all species in the system automatically.
Best
Old   November 26, 2019, 06:55
Default Mass transfer source term in porous media
Pallavee Dhekne
ppdhekne is on a distinguished road
How to define mass transfer source term (mass diffusivity) in porous media? Which model should i use for mass diffusion through porous media? Thanks in anticipation
ppdhekne is offline   Reply With Quote
Old   November 26, 2019, 10:43
david
Best
Could you help me with my problem here: UDF code for water absorption in Polymer
Old   June 23, 2021, 11:01
Beatriz
azores is on a distinguished road
Hello Weiqiang Liu,
I have a similar problem. Could you provide your UDF to calculate diffusion coefficients for each species?
Thanks in advance!
Best regards,
Beatriz
azores is offline   Reply With Quote
Old   June 23, 2021, 11:03
Beatriz
Best
Hello Weiqiang Liu,
Thanks in advance!
Best regards,
Beatriz
mass diffusivity, mixture material, udf
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 1 May 19, 2020 22:13
Transport coefficients for chemical species Larrein Main CFD Forum 0 January 5, 2016 16:57
UDF carbon conversion papteo Fluent UDF and Scheme Programming 1 August 18, 2011 08:32
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
Species diffusion coefficient iceabc FLUENT 1 June 10, 2004 11:04
