Save case and data in a different folder using Journal
Old   June 14, 2019, 13:07
Default Save case and data in a different folder using Journal
South Yorkshire
asking is on a distinguished road
I am running the same model multiple times, just changing one parameter (inlet velocity). I wrote different journals that change the velocity but I am having problems saving the data and case files in a different folder. That way, when I run the model next time it wont overwrite the files.
Basically, I want to save the data, case, and output files (displacement) in a different folder.
Thanks !
Regards,
Daniel
asking is offline   Reply With Quote
Old   June 17, 2019, 03:45
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
make a loop and save your case/data files
(do ((i 1 (+ i 1)))((> i 3))
(ti-menu-load-string (format #f "file read-case \"YOU_CASE_FILE.cas\" OK \n" i))
(ti-menu-load-string (format #f "file write-data \"FULL_PATH_WITH_NAME_~a\" \n" i))
you will get
FULL_PATH_WITH_NAME_1
FULL_PATH_WITH_NAME_2
FULL_PATH_WITH_NAME_3
best regards
AlexanderZ is offline   Reply With Quote
fluent, tui
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times vidyadhar ParaView 9 May 20, 2020 21:06
save case & data Saman95 FLUENT 1 August 12, 2018 07:09
save PARTICLE information in CASE and DATA Alex FLUENT 1 September 1, 2010 11:01
how to save case data and data during iteration? JOHN FLUENT 3 October 10, 2006 20:40
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
