the unit of molar mass in fluent
Old   June 11, 2019, 17:54
Default the unit of molar mass in fluent
Weiqiang Liu
Weiqiang Liu is on a distinguished road
Hi all,
I need to define mass diffusion coefficients with UDF. However, I am very confused about the unit of molar mass fluent uses.
I put two equations below one is how fluent calculate binary diffusion coefficients and the other is how knudsen diffusion coefficient is calculated.
I checked the unit in fluent user guide and found that they use kg/kmol as molar mass unit. However I found the unit of molar mass in the second equation is kg/mol. I am wondering what is exactly the unit of molar mass fluent solver passes to UDF?
Best regards
weiqiang
Weiqiang Liu is offline   Reply With Quote
udf, unit of molar mass
Erron: FLUENT received fatal signal (ACCESS_VIOLATION) in DPM Heat and Mass Transfer Melvin FLUENT 2 November 17, 2016 02:06
Mass Flow Rate in Fluent mhakimakbar FLUENT 2 April 22, 2016 14:12
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
CFX overwhelming Fluent in mass convergence of boundary layer separation case Pierre1 FLUENT 7 March 26, 2015 22:43
unit of fluent yinyue FLUENT 0 November 3, 2004 09:57
