June 7, 2019, 06:38 |
Porous media modelling vs outlet vent BC
Amey Raju Pawade
Rep Power: 7 |
I am simulating an Air filter assembly, which has a perforated sheet with 50% opening area and 1.6 mm thick at the outlet. I can model the perforated sheet as outlet vent BC by providing the loss coefficient as obtained by empirical relations and outlet gauge pressure of 0 Pa. The other way is to assume the volume of the sheet as a porous media and model the particular volume with the calculated inertial resistance coefficient and the outer face as pressure outlet BC with gauge pressure of 0 Pa. Are both the approaches correct and can be used? Help will be appreciated. |
fluent 14.5, outlet boundary condition, outletvent, porous formulation, porous media model |
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions | Vishnu_bharathi | CFX | 12 | November 21, 2017 07:56 |
How to Modelling Cooling Tower using Porous Media | harkerz | FLUENT | 2 | June 6, 2017 09:31 |
Modelling aflow through a porous media | EBehnamtalab | FLOW-3D | 0 | May 30, 2017 07:23 |
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 05:10 |
porous media modelling | sekar | FLUENT | 0 | January 21, 2008 03:27 |
