Alejandro Valeije
Rep Power: 11 ![]() |
Hi everyone,
I'm trying t orun a multiphase simulation, with multiple inlets, some of which have very high mass flow values in them, resulting in a high Mach value. Since the case has multiple phases, and the wet steam model doesn't work in this particular case, I have to run a pressure-based solver. The problem is that pressures and densities I'm getting at the inlets doesn't match at all with the results I'm supposed to get. I'm talking of getting a 3.5 kg/m3 density when I should have 48 (I supposed this is due to the error calculating the pressure field). Mach numbers are in the order of (0.8, 1) locally at the inlets, so I assume that it might be a problem related to the solver. Is there any way of solving these types of cases? Thank u very much Alex |
Ideal Cell Type for Multiphase Simulations | jpando | Siemens | 0 | December 16, 2014 10:47 |
Shock tube at high mach numbers-ANSYS Fluent | dsn2491 | FLUENT | 3 | May 21, 2012 20:07 |
High Local mach number for sub sonic flow | kali | CFX | 0 | November 2, 2006 10:23 |
non-dimensional analysis in Fluent | Endee | FLUENT | 8 | September 7, 2005 16:16 |
High Mach number flows | Riaan | FLUENT | 9 | May 7, 2005 15:49 |
