June 4, 2019, 14:42 |
Mesh convergence problem
Louis Belgrand
Hi, I have a problem about mesh convergence.
My problem is a 2D jet impingement on a moving wall. After a VOF simulation and guess the interface between the liquid and the air, i do a simulation like a laminar pipe flow problem (with just the liquid) The boundaries condition are shear stress equal at 0 at the free interface and no slip condition+ velocity for the moving wall. I have also a edge for flow inlet and one for pressure outlet. You can see the geometry with the mesh in the attach files I do a mesh refinement study by doubling the number of cells in each direction twice. But, i don't have a mesh convergence but something like a depressure offset (see "pressure at the wall" in the attach files). When I try do the same study with a stationary and no slip wall in place of moving wall, I have a mesh convergence. I don't what's wrong. I try setting to no slip and just the areas very close to where the free surface interface meets the surface, but it's not better... Someone of you are already confronted at this problem ? Thanks |
2d jet impingement, boundaries condition, mesh convergence, moving wall |
Convergence problem with mesh? | tareqkh | Main CFD Forum | 0 | July 13, 2016 18:38 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh | sc.park | OpenFOAM Meshing & Mesh Conversion | 1 | March 13, 2016 14:28 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 09:52 |
Convergence problem when ustructured mesh is used. | SangJin Ryu | Siemens | 3 | October 5, 2000 21:26 |
