Defining Initial Species Mixture for Driven Gas in Shock Tube |
June 4, 2019, 01:28 |
Y Yang
Rep Power: 14 |
Dear All,
I try to simulate a shock tube simulation with a mixture of O2 and Ar in the driven tube. I looked into google and found that patch can be used to define the pressure difference between driver and driven tube. However, I cannot do the same for the initialization mole fraction in the mixture for O2 and Ar. Can somebody help me how should I solve this issue? Thanks! |
June 4, 2019, 12:05 |
Lucky
Rep Power: 66 |
You can patch the mixture the same way you patch the pressure.
The only thing that can go wrong is you can't find the variable. The variable is going to depend on what your model is. |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 15:05 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 14:40 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 14:38 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
