Rotating arm turbulence
Old   May 31, 2019, 07:12
Default Rotating arm turbulence
collie is on a distinguished road
Hey all.
I have a problem with a simulation that I am running. The simulation is a rotating arm within an octagonal enclosure. The purpose of the simulation is to estimate the minimum boundary between the end of the arm and the enclosure wall. The arm rotates at 175 rad/s.
I am using a realizable k-epsilon turbulence model with standard wall functions. I have chosen a steady state solution with a moving wall.
Online theory suggests that turbulence of 10% is considered high. The turbulence that my model is outputting is at least 10 times that.
Any help that anyone can give is appreciated. Am I using the correct model? Is there a better way to estimate the minimum distance between the arm and the wall?
Cheers,
collie
collie is offline   Reply With Quote
fluent 19.1, rotating body, turbulence intensity
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 15:18
Only two turbulence options available in CFX Pre Jack001 CFX 5 March 30, 2016 03:47
ISSUES: Rotating VS Non-Rotaing Domains gigiboumba CFX 3 April 26, 2014 08:22
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 05:30
HELP: rotating mesh turbulence model sunlight007 Siemens 2 October 16, 2004 20:18
