Obtaining the value of heat flux on the opposite side of boundary
Old   May 28, 2019, 18:16
Default Obtaining the value of heat flux on the opposite side of boundary
Kronecker delta is on a distinguished road
Hello all,
I am attempting to model melting by calculating enthalpy in the PCM subdomain. The domain is attached below.
Basically, I am using a UDS for enthalpy and in order to describe its change on the PCM side of the boundary I need the value of heat flux transported through the boundary, so I would need to obtain the value of heat flux on the wall side (or temperature gradients normal to boundary). I have tried using BOUNDARY_HEAT_FLUX macro, but to no avail. As I understand it, I would need to get access to cell and face values of temperature of the adjacent (wall) cells, and I am unable to do so, and I would appreciate your help.
Also, if there is a better/simpler way that I have not considered or if I am wrong about something, please notify me, I would be grateful for any kind of advice you might have.
Kronecker delta is offline   Reply With Quote
boundary heat flux, fluent, udf
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 10:49
How to set the Heat Flux boundary condition at Outlet creddy_trddc CFX 3 September 21, 2011 08:44
