Ansys Mesh Adaption
Old   May 27, 2019, 12:32
Default Ansys Mesh Adaption
jhs
Julius
jhs is on a distinguished road
is there a way to use mesh the adaption threshold (in dynamic mode) as a fraction of a current value not the absolute value?
Example:
/adapt/set/refine-mesh? yes
/adapt/set/coarsen-mesh? no
/adapt/set/min-number-cells 1000
/adapt/set/max-number-cells 1500000
/adapt/set/grad-vol-weight 0.85
/adapt/set/max-level-refine 15
/adapt/adapt-to-gradients q-criterion space-gradient 0 1e+4 0 yes 20
Here the adaption occours with a threshold of 1e+4 (actual value is around 1e+5 in the beginning; meaning ratio is 0.1).
Dynamis mode means theat the actual value might be much higher in the end so a fixed threshold isnt really apropriate, but I havent found a solution yet.
Can some kind of a function be used?
Any help would be appreciated.
jhs is offline   Reply With Quote
adaption, ansys, fluent. cfd, mesh, tui
A CFX-POST error (ver 14.5.7) wangyflp88 CFX 2 July 22, 2017 01:17
CFX FSI Fatal Error unbanana CFX 0 October 3, 2015 06:57
[ANSYS Meshing] ansys mesh, stirred tank reactor delplatl ANSYS Meshing & Geometry 0 August 11, 2015 06:25
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
