Effect of mushy zone constant on isothermal phase change
Old   May 22, 2019, 05:25
Post Effect of mushy zone constant on isothermal phase change
Emil Helgren
emilhelgren is on a distinguished road
When modeling isothermal phase change ( T_solidus = T_liquidus) i expected to have a non-existent or at least very thin mushy zone, since there is no diffusion of latent heat*. When i observed a zone with a significant thickness (low_const.png) i thought about what might cause this. I came up with the explanation that because the solid phase is simulated as a fluid with a very big momentum sink**, there is still some little bit of convection of latent heat, since the velocity is not completely damped while
0 < Latent Heat content < Latent Heat of Fusion
And this would create the zone seen on the image. From this reasoning, increasing the mushy zone constant (which determines the steep-ness of the damping in the momentum sink term) would make the zone thinner, since the velocity is damped quicker in response to freezing (/ ramped up quicker in response to melting), but this is not what happened when i increased it from 10^5 to 10^8 (which is the limit of the recommended span), as can be seen on (high_const.png).
Does anybody have an idea what might cause this? Do you agree with the reasoning? Why is there a mushy zone still, and how to get rid of it(since there is no zone in the melting of water in reality)?
*As can be seen in the formulas used by Voller and Prakash in this paper:
https://www.sciencedirect.com/scienc...17931087901529
Which is the source provided in the ANSYS 18 theory guide for the case of T_solidus = T_liquidus in chapter 18.4 (Energy Equation)
**(A_mush * vel * (1 - LF)^2/(LF^3 + 0.00001))
emilhelgren is offline   Reply With Quote
enthalpy equation, isothermal phase change, liquid fraction, mushy zone
Is there a VOF (CST) foam code for phase change into the air media? Asghari_M OpenFOAM Programming & Development 4 February 17, 2021 11:41
Journal file error magicalmarshmallow FLUENT 3 April 4, 2014 13:25
Solid/liquid phase change fabian_roesler OpenFOAM 10 December 24, 2012 07:37
Segmentation Fault in fluent3DMeshToFoam cwang5 OpenFOAM Bugs 23 April 13, 2011 16:37
Mushy Zone constant default? Kjell Magnusson FLUENT 2 December 11, 2006 09:48
