sinusoidal velocity inlet
Old   May 21, 2019, 11:09
Default sinusoidal velocity inlet
serrar is on a distinguished road
Dear expert,
I simulate a turbulent flow, I used a sinusoidal function that depends on time as input velocity. and its via UDF.
Regarding the time step I took in an article (even if the number of meshes is a little different), the problem is that ANSYS FLUENT exceeds the time interval that I defined.
1- Does it make sense?
2- How to force the convergence of the simulation?
3- Is there a tool under FLUENT to estimate the optimal time step?
Best regards,
SER
serrar is offline   Reply With Quote
convergence
simpleFoam: Non-uniform mesh near inlet & outlet causes incorrect velocity profile? Zaphod'sSecondHead OpenFOAM Running, Solving & CFD 0 January 28, 2015 06:17
How to define a fixed velocity for a given mass flow rate on inlet mqasimali FLUENT 2 April 12, 2013 18:24
Transient sinusoidal velocity inlet mrestrepo30 FLUENT 2 September 27, 2010 13:03
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 12:21
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
