Model for Mixing two fluids at near molecular level |
May 20, 2019, 15:08 |
samm
Rep Power: 7 |
Hello all,
I want to mix two fluids(Liquid kerosene(spray)-air) at near molecular level in fluent. which will be a appropriate model to simulate this. Any suggestion please... Thank you. |
May 21, 2019, 10:00 |
samm
Rep Power: 7 |
Any suggestion please.....
May 22, 2019, 02:26 |
veerappan
Rep Power: 7 |
you can use ..multi phase model with mixture you can use or volume method u can use
May 22, 2019, 03:34 |
samm
Rep Power: 7 |
Thank you for your kind reply,
But multiphase models mix the fluid in macro level right? correct me if I'm wrong. then how can I spray liquid if I choose multiphase model …please tell me your valuable suggestions. Thank you jegan. |
May 22, 2019, 17:30 |
Lucky
Rep Power: 66 |
The fluid particle model is macroscopic. We do not talk about molecular effects in a fluid except via other models. Spray modeling, chemical reactions, etc. are all modeled at the macroscopic level in fluids. If you want to simulate molecular stuff, go somewhere else.
kerosene combustion, mixing fluids |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 08:18 |
[snappyHexMesh] Edge Refinement | fracasce | OpenFOAM Meshing & Mesh Conversion | 3 | December 2, 2017 14:30 |
Level set method with Cross wlf viscosity model COMSOL5.2 | anouss11 | COMSOL | 0 | June 5, 2017 11:21 |
manualInjection model in sprayFoam | Mentalo | OpenFOAM Running, Solving & CFD | 1 | April 2, 2014 10:29 |
Initializing fluid level on VOF model | Daniel | FLUENT | 5 | July 3, 2009 04:45 |
