May 19, 2019, 18:16 |
how fluent calculate energy equation?
Weiqiang Liu
Rep Power: 9 |
Hi all,
I am doing a porous media combustion with fluent. In the literature, I found the energy equation is solved with enthalpy change. I also know that energy equation sometimes can be represented with specific heat. The author mentioned that both enthalpy and specific heat is temperature dependent. I defined temperature function of specific heat. However, I cann't see any reason I should defined temperature function of enthalpy. I wonder does the author mean enthalpy is a function of temperature because specific heat is temperature dependent and enthalpy is a function of specific heat. Therefore, enthalpy is temperature dependent indirectly? I put the energy equation in the paper below: It's more a question of thermodynamics than CFD. Can anybody help me? Best regards. |
May 20, 2019, 00:36 |
Alexander
Rep Power: 34 |
is you assume, that specific heat is constant, than enthalpy is not a function of temperature
best regards |
May 20, 2019, 09:14 |
Lucky
Rep Power: 66 |
What are you even discussing... Enthalpy depends on temperature or we'd violate at least one law of thermodynamics....
Enthalpy is heat (or heat potential) and temperature (from kinetic theory) is the average kinetic energy of the molecules in the volume. More temperature = more kinetic energy = more enthalpy. |
May 20, 2019, 10:35 |
Weiqiang Liu
Rep Power: 9 |
May 20, 2019, 10:57 |
#5 | |
Weiqiang Liu
Rep Power: 9 |
May 20, 2019, 12:05 |
Lucky
Rep Power: 66 |
You should state specifically your setup because it varies.
For combustion modeling for example, you normally use the nasa 7-polynomials which specifies the specific heat + a reference enthalpy and you are done. |
May 20, 2019, 12:17 |
Weiqiang Liu
Rep Power: 9 |
is it because anthalpy is an integration of specific heat plus standard state enthalpy. if I know temperature dependent specific heat, then I know enthalpy under different temperatures. By mass fraction weighted calculation, I know enthalpy of the whole system?
enthalpy, specific heat, temperature dependent |
Source Term due to evaporation in energy transport equation | styleworker | OpenFOAM Programming & Development | 3 | September 7, 2022 03:09 |
Multiply viscous dissipation with some constant in energy equation in fluent. | alexskerhut | FLUENT | 2 | June 8, 2016 01:56 |
Source term energy equation for reactive flows | DaIN | Main CFD Forum | 0 | October 6, 2011 15:11 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Momentum, energy Equation in Fluent | Seeker01 | FLUENT | 2 | January 29, 2003 18:27 |
