Mass Flow from expression problem
Old   May 15, 2019, 15:08
Default Mass Flow from expression problem
Ziga
Zigec is on a distinguished road
Send a message via Skype™ to Zigec
I have this one problem. A little background: I have an empirical equation from which the mass flow is calculated. In the equation there are only constants, except for one, which is the pressure in a point, which I know how to read it etc. Nothing hard, except when I first wanted to do this with an UDF, but not even the Ansys Support knows why Fluent freezes in the moment you press Initialization.
They told me there is a option to do this over the Named Expressions, which I did. Basically it works fine, except it doesn't. The problem is Fluent reads the pressure in each iteration and calculates a new mass flow each time, which makes it to diverge. I need Fluent to only calculate the new mass flow each time step and not iteration. Any one knows if this is possible and if, how to do it? I just want to do 200-300 iteration in each time step before changing the inlet condition.
Best regards,
Ziga
Zigec is offline   Reply With Quote
Old   May 23, 2019, 15:14
acalado's Avatar
André
acalado is on a distinguished road
Can you share the expression you have? Are you taking the average pressure over a surface?
Sapere aude!
acalado is offline   Reply With Quote
expressions, fluent
Outlet boundary condition in interFoam Andrea_85 OpenFOAM Running, Solving & CFD 51 July 20, 2017 14:31
Exit Corrected Mass Flow Rate Mesh Sensitivity Study s__s__s CFX 4 July 20, 2016 12:46
total mass loss/gain--simulating taylor couette flow nwpukaka OpenFOAM Programming & Development 0 February 12, 2014 19:57
Problem for Mass flow average in Post... ST CFX 2 October 27, 2005 14:35
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
