Fluid Damper Simulation
Old   May 7, 2019, 08:25
Default Fluid Damper Simulation
Randal Wang
Randal0 is on a distinguished road
I am trying to simulate a fluid damper(pictures are attached below).
However I tried lots of methods, always failure.
The method I use is layering. I set "moving wall" in picture as rigid body, failed, as is shown in the third picture.
Can anybody give me some advice?
Thanks a lot!
Randal0 is offline   Reply With Quote
Old   May 7, 2019, 13:00
Randal Wang
I try to set the full domain as rigid body, and the left and right wall as stationary, the piston and piston rod (moving wall in the picture) as rigid body.
Failed again.
Old   May 20, 2019, 17:58
Default Has anyone modelled a MR damper CFD/CFX in ANSYS?
yubraj
yubraj2019 is on a distinguished road
I need a full guideline. Can anyone help me with these issues?
yubraj2019 is offline   Reply With Quote
Old   May 21, 2019, 02:24
yubraj
Randal0
would you please help me for MR Damper CFD
dynamic mesh, fluent, layering method, piston cylinder
can not run simulation for body sinusoidal movement between two different fluid zones M.Hodali Autodesk Simulation CFD 0 December 17, 2018 18:07
Weird fluid distribution in the interMixingFoam simulation HectorLee OpenFOAM Running, Solving & CFD 0 July 11, 2018 10:55
Problem in CHT simulation with high heat capacity fluid Fole FLUENT 1 September 26, 2017 09:42
Miscible fluid flow simulation j.patel Main CFD Forum 0 November 6, 2014 05:54
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
