Taylor-Couette simulation
Old   May 5, 2019, 10:34
Smile Taylor-Couette simulation
Samuele Bagala
samufluent is on a distinguished road
Hi everyone,
I am doing a simulation about a Taylor-Couette cylinder (coaxial tube cylinder) by using Ansys Fluent 2019. The system consists about a plain (section in 2D of the Taylor-Couette cylinder) in which pure water flows from the bottom to the top. The internal cylinder (wall in 2D) rotates and the external one is fixed. My purpose is to calculate the absorbed power at different rotation speeds of internal cylinder.
I would like to ask two questions:
1) What is the best method for turbulence of my system? I know that the k-epslon is not adequate for systems in which there are rotating components,
2) How can I understand in a system about this if the flow is laminar or turbulent? I found the specific Reynold's number for this system, but i have not found a boundary criteria (for example Re>2100 for flow in a tube).
Thank you
samufluent is offline   Reply With Quote
taylor couette, taylor couette flow
Convergence Problem - Transient Simulation gemxx Main CFD Forum 0 July 15, 2018 10:36
Mapping Field Data for Mesh Regions from Another Simulation veterator OpenFOAM Pre-Processing 1 July 10, 2018 06:28
Surface Source - Fixed Temperature? robtheslob FloEFD, FloWorks & FloTHERM 18 May 12, 2017 03:28
Simulation FPEs - turbulence for transient and steady-state? DaveR OpenFOAM Running, Solving & CFD 5 March 5, 2017 16:06
setting up a simulation with multiple interactions phandy OpenFOAM Running, Solving & CFD 1 October 6, 2014 04:16
