How to show the blending function for DES model in Fluent
Old   May 2, 2019, 09:27
Default How to show the blending function for DES model in Fluent
ziyixy is on a distinguished road
I found the blending function for DES model in CFX,but the variable doesn't exist in Fluent results.
In a thread it is stated that blending function can be turned on by TUI command "/solve/set/expert/ n y n",I tried it and the blending function F1 and F2 appeared in the list,but not for the blending function for DES model.Is there a way to define the variable in Fluent,so I can plot contour to show weather the LES model is activated.
Thanks in advance
ziyixy is offline   Reply With Quote
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
Wall damping function in Fluent using LES with standard smagorinsky sgs model (Cs=1) lxlylzl FLUENT 4 October 13, 2018 19:35
standard wall function UDF fluent (k-omega model) alinik Fluent UDF and Scheme Programming 0 April 27, 2017 19:05
Mesh quality and wall function in FLUENT - k-omega model newcomer ANSYS Meshing & Geometry 1 May 19, 2011 04:00
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
