Tamoor
Rep Power: 0 ![]() |
Hello!
I am modelling gaseous combustion in fluent using Eddy dissipation and k-epsilon models. I have species profiles (CO,CO2,H2O,O2,CH4) at inlet which I implement using UDF. I am only modelling fluid domain but I want to reject heat from the fluid domain into surroundings (which is used for steam production). I want to remove 13MW of heat from walls and I am trying to use heat flux boundary condition at walls. But I get negative temperatures at walls when I put (negative heat flux) calculated by 13MW/wall surface area. There is enough heat available at outlet of geometry (54MW) which I can see from Flux reports. But I want the 13MW to be removed from walls, any help would be really appreciated. |
combustion modeling, heat flux |
Heat transfer between wall and air in Fluent | jimmy871013 | FLUENT | 6 | April 27, 2018 02:00 |
Why Fluent give me wrong heat transfer coefficient? | mariam.sara | FLUENT | 10 | July 28, 2015 11:28 |
Separate Convective and Radiative heat transfer in CFD post using fluent as a solver | Lemanes | FLUENT | 1 | July 6, 2015 10:31 |
Problem with conjugate heat transfer in Fluent | JianT88 | FLUENT | 0 | March 16, 2015 08:17 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
