Liquid compressibility as a function of hydrostatic pressure |
April 30, 2019, 13:07 |
sri krishna
Rep Power: 8 |
I am trying to model depressurization of an oil well. The well is ~5000m deep and is filled with water at high pressure. There is a huge hydrostatic pressure at the bottom of the well because of the vertical depth. Is there a way to account for compressiblity of water with hydrostatic pressure. Seems like the compressible liquid option only takes into account the static pressure and not the hydrostatic head.
Really appreciate the help. Thanks in advance. |
April 30, 2019, 13:59 |
Lucky
Rep Power: 66 |
April 30, 2019, 15:26 |
sri krishna
Rep Power: 8 |
Please see the setup and the results. I do not think it is working.
May 1, 2019, 11:32 |
Lucky
Rep Power: 66 |
There is high density on the right and low density on the left. What else do you want?
May 1, 2019, 11:36 |
#5 | |
sri krishna
Rep Power: 8 |
I am able to get the correct hydrostatic head by setting the reference density to 0. |
May 1, 2019, 12:37 |
Lucky
Rep Power: 66 |
If you want to see the hydrostatic pressure in the static pressure plot, then you need to set the operating pressure to 0. Yes that is correct.
I don't get what result you expect to see that is not shown here. Also, boundary conditions = ??? |
May 1, 2019, 12:39 |
sri krishna
Rep Power: 8 |
Thank you and appreciate the input.
May 1, 2019, 12:43 |
Lucky
Rep Power: 66 |
Also why did you set (or leave as default) the maximum density ratio to 1.1?
May 1, 2019, 12:47 |
#9 |
sri krishna
Rep Power: 8 |
Yes, that was the default max density ratio and the density I expect falls within this range.
compressible liquid, hydrostatic pressure |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
[mesh manipulation] refineMesh Error | mohsen.boojari | OpenFOAM Meshing & Mesh Conversion | 3 | March 1, 2018 22:07 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
