A Saw-tooth/unsmooth pattern in Pressure Distribution |
April 29, 2019, 14:10 |
Hello Everyone,
I tried to use fluent to simulate the famous Onera-m6 wing. but results in a saw-tooth pattern in the generated pressure distribution. The mesh I used was a multi-block structured mesh generated by ICEM. the mesh quality should be acceptable as above 0.3. In fluent I used density-based steady solver with standard S-A turbulent equation, while the fluid was chosen as ideal gas with Sutherland as viscosity equation.Other solution methods are attached. the boundary condition are chosen as farfield/symm/no-slip wall. the mach number was 0.84 and AOA was 3.06 deg. However I got the weird unsmooth pressure distribustion(both can be observed from the tecplot figure and fluent pressure contour) Anyone please provide a reason and solve for this. thanks. |
April 29, 2019, 14:14 |
a ideal figure may look like this. However I am unaware where those sawtooth shape come from.
fluent |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 14:04 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 17:29 |
Setting up the pressure variation due to tornado in a duct(UDF)+animation | guillaume1990 | FLUENT | 0 | March 3, 2014 12:59 |
Does star cd takes reference pressure? | monica | Siemens | 1 | April 19, 2007 12:26 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 14:19 |
