load an already compiled UDF on a separate machine |
April 29, 2019, 12:39 |
ali
Rep Power: 18 |
Hi all,
Is it possible to compile a UDF on a machine and copy/paste the udf library on a separate machine, and then load the it there? Thanks, |
April 29, 2019, 13:49 |
Lucky
Rep Power: 66 |
Yes it is, otherwise you'd never be able to run Fluent in parallel. Are you having trouble doing it or just a question?
April 29, 2019, 14:53 |
ali
Rep Power: 18 |
Well I could not find the way to load a UDF, that is already compiled on another machine, onto a Fluent simulation on a separate machine.
How can I do that? I am having this problem and would like to solve it, it is not just for the sake of knowing. Thanks luckyTran |
load, udf, udf compilation, udf loading problem |
The UDF library you are trying to load (libudf) is not compiled for 3d on the current | vigii | Fluent UDF and Scheme Programming | 37 | October 3, 2019 07:16 |
UDF: How to load data from an external file into a vector | EmiS | Fluent UDF and Scheme Programming | 17 | January 14, 2019 02:55 |
Compiled UDF on BATCH file | Bionico | Fluent UDF and Scheme Programming | 3 | June 4, 2018 17:44 |
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF | acasas | CFD Freelancers | 1 | January 23, 2015 08:26 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 22:38 |
