Stagnant Zone
Old   April 29, 2019, 01:24
Question Stagnant Zone
Fidho.im is on a distinguished road
Hi everyone,
I did a simulation on Euler-Euler gas-liquid bioreactor and the result seems good. Afterward, i want to find the stagnant zone for liquid phase (the percentage of volume with low velocity per total volume). How can i discover the volume under certain velocity (lower than 10^-3 m/s)?
I would be really glad if there are some suggestions
Thanks
Fidho.im is offline   Reply With Quote
Old   May 9, 2019, 14:46
Smile Stagnant Zone
Hi
I am still wondering how to find the volume of the stagnant zone and i think it might be possible to do that through expression in CFD-post. What would be a good way to do that in expression? I mean how to write the expression since there is no formula about it
I hope someone can help me with this issue
Regards
Old   January 22, 2024, 09:48
Default Stagnant Fluid
Gabriel Binelli
ABgabriel13 is on a distinguished road
Originally Posted by Fidho.im View Post
Hi
Regards
Hey, were you able to do this post-processing?
ABgabriel13 is offline   Reply With Quote
Old   January 24, 2024, 09:10
North Star is on a distinguished road
Hey,
Would setting an iso-clip with your defined max velocity to create a surface, and then using surface integrals --> sum --> mesh --> cell volume to obtain a total volume work? You could then multiply this value with the average volume fraction (within the iso-clip) of your desired phase to obtain an approximate value, but I'm just guessing here.
North Star is offline   Reply With Quote
cfd - post, fluent
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 02:47
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
